Why curtain definition 1/6 does not work
When I define geometry in the column I entered 25/160, it gives the warning that the narrow side cannot be less than 30 cm, while this element should be perceived as a curtain.
Re: Curtain definition does not work at 1/6 height
"durukmuhendislik":2y2aqp7i" said:
25/160 When I define geometry in the column I entered, this element should be perceived as a curtain, but it gives a warning that the narrow side cannot be less than 30cm[/ quote] Hi, You need to enter the curtains with the curtain command.
