saridurmus
Hi Friends, Who will prepare the 16.2.2.2 Soil Geotechnical Report in the Design of Foundation Soil and Foundations under the Earthquake required in Chapter 16 of the TBDY 2018 Regulation. Can I have your views?
Hello; Geotechnical report foundation design in static project While preparing the geotechnical report, a preliminary analysis should be made in the static project and the foundation pressures formed at the base of the structure (for settlement calculations on the foundation ground, etc.) should be determined and the total horizontal force acting on the structure (for foundation slip controls) should be determined. Therefore, the geotechnical report should be included in the static project from the static project. data transfer is necessary and mandatory Submit static pre-study to generate data for geotechnical report You can give a summary in the form of a table added by İsmail Bey. For now, the program does not automatically prepare this table; You can give G+Q, 1.4G+1.6Q for raft foundations, BASE BASE PRESSURE GRAPH for the worst combination with earthquakes, and Total horizontal Force Vt acting on the base of the structure. For continuous and single foundations, in addition to Vt, you can prepare and submit a separate foundation report for G+Q, 1.4G+1.6Q, Earthquake combinations. Best regards."huseyinakkus56":3vkp56e4" said:For God's sake, does anyone have a new-format Geotechnical report? Otherwise, I would take it and put it in the Geotechnical report so that we wouldn't discuss it. Isn't the geotechnical report prepared for suggestion-warning purposes before the project? Is it reasonable to get any data from the static report? Help me, I'm miserable..
Vt values are printed in the dynamic analysis report.You can take the dynamic analysis report of your project and add it to the report you prepared."huseyinakkus56":g5dryb35" said:Thank you for your help. I'm preparing a report as you mentioned, but we get the Vt value from statics, the municipality says to calculate it. It says to transfer whatever value we get to the geotechnical report. As far as I can see, we can get the Vt directly from the report as a result. Can we get these calculations-transactions from the report?
Vt calculated from Modal analysis is often 10% smaller than Equivalent Static Vt. The previous stage of Vt calculation is Modal Vt values calculated for each mode These Modal Vt values calculated for each mode are combined with CQC and found Vt. Any magnitude calculated in dynamic analysis is like this. Column beam end forces, plate stresses, Foundation related values. So almost everything the program calculates is calculated as Modal and CQC combined is done."2m project":126wzwrt" said:You don't have the chance to manually calculate the Vt you found with modal analysis. Besides, no one can say, "Prove this value from where you got this value from," the project author has this responsibility. Let's prove the calculations manually.Sent via iPhone using Tapatalk
By the way, can anyone help with this?"huseyinakkus56":2m6g57qd" said:I couldn't make a properly distributed load effect on the curtains. Nothing happens when I select the objects.
Well, Mr. İsmail, are the parameters in the image not available in dynamic analysis? For example, when we replace these parameters in TBDY 4.19, are we going to calculate and combine CQC for each mode?"Ismail Hakki Feeds":3uu6vn0w" said:Vt calculated from modal analysis is often 10% less than the Equivalent Static Vt. The previous stage of the calculation of Vt is the Modal Vt values calculated for each mode. The Modal Vt values calculated for each of these modes are combined with the CQC to find Vt. This is the case with any magnitude calculated in dynamic analysis. Column beam end forces, plate stresses, Foundation related values. In other words, almost everything that the program calculates is calculated as Modal and CQC combination is done."2m project":3uu6vn0w" said:You have no chance to manually calculate the Vt you found by modal analysis. Besides, no one can say, "Prove this value from where you found it," in this responsibility project author. It gets to the point where it's ridiculous and inextricable. Then let's prove all static calculations manually.Sent via iPhone using Tapatalk
Also, the TBDY 4.19 Formula Esvalue you mentioned is related to the earthquake load calculation. This value (Equivalent Vt) is already calculated and printed in the program."Ismail Hakki Feeds":14mwj4ti" said:Vt calculated from modal analysis is often 10% less than the Equivalent Static Vt. The previous stage of the calculation of Vt is the Modal Vt values calculated for each mode. The Modal Vt values calculated for each of these modes are combined with the CQC to find Vt. This is the case with any magnitude calculated in dynamic analysis. Column beam end forces, plate stresses, Foundation related values. In other words, almost everything that the program calculates is calculated as Modal and CQC combination is done."2m project":14mwj4ti" said:You have no chance to manually calculate the Vt you found by modal analysis. Besides, no one can say, "Prove this value from where you found it," in this responsibility project author. It gets to the point where it's ridiculous and inextricable. Then let's prove all static calculations manually.Sent via iPhone using Tapatalk
