When the mold plan is received, dimensioning on the mold plan
Ahak
Hello friends, good work everyone, When I get the floor mold plans after creating the model, when I get the floor mold plans, more than 1 axis dimensioning appears on the mold plans. Is there anyone who encounters such a problem or can anyone help with the solution? thank you.
Re: About dimensioning on the mold plan when we receive the mold plan Hello, if you add the İdecad project file to your message, we can examine it.
Re: About dimensioning on the mold plan after receiving the mold plan Probably your problem is caused by the tick in the attached picture. Select the formwork plan section and enter its properties. If you remove one or both of the ticks, your problem will be solved. Of course, "measure the axles" at the bottom will suffice. But if you want to avoid double axles, remove both signs. Note: If you don't want it to repeat in other plan drawings, get the properties of the section with the Get settings from object command after correcting it.
