When I give jeans on the floors, it always says 0.00.
Re: problem of giving elevation Hello, enter the elevation settings and select only the "write floor level" tab from the general settings. Good luck with.
Re: The problem of giving jeans My settings are already the same, but when I select the jeans and click on the area, it says 0.00 on each floor.
Re: problem giving jeans
I just started drawing. There is ground and 1st floor. When you give jeans on the 1st floor, it says 0.00. You can download it from the link above. Thank you very much for your attention.
Hello, We opened your project and examined it and entered the elevation values. We present it to you in the plugin, you can examine the elevation value settings and use them as we have done. (When you give the elevation value, you can make more accurate elevation if you select the basic unit from the unit settings.) Take it easy.
