What should we pay attention to in the design of such projects?
M.sa
Hello, I would appreciate if you can help with the errors and defects of the attached roof model. What should we pay attention to in the design of such projects?
Re: STEEL ROOF Hello; At the end of the sloping end of the roof, will the lower end of the beams be consoled in this way or will it be supported by another element in the structure, if it will be connected to reinforced concrete columns, if you connect these beams by entering a steel column with a length of 50-60 cm in between, the structure will exhibit a more appropriate behavior, currently 1.mod 3.2 sec. looks. You have also entered the auxiliary elements with a single sub-beam command. However, there is no flooring on it. In order to enter the loads on them, model these elements again by using the purlin command instead of the 1-single sub-beam command. Then make a coating entry on the purlins. 2- Enter the required fixed, mobile and snow loads in the loads section of the coating settings. Good work.
Re: ÇELİK ÇATI Thank you for your interest, Ms. Nurgül. I would like to ask one more thing. We want to make only welded joints, not L angles in the joints in purlins. Is there a way to quickly model this
Re: STEEL ROOF This is the final version of my model, but I could not solve the inadequacies and negative situations, I would appreciate if anyone can help.
Re: STEEL ROOF Hello; There was a wall load on the beams you just added, the edited version is attached. Your beams that seem insufficient are those connected by 3 beams from the other direction, please increase the cross sections Good work.
