Re: What kind of connection is formed with the beam in the weak direction of the column Hello; If you consider the field and the application, you can see the difference. The butt plate overlaps the cross-section radius of the body, this is not very convenient, bolt placement and similar works will be more difficult. However, if you say that there is no problem in the field, it is your decision, we just stated it as a suggestion.
