What are the best way to drawing the Flat slab reinforcement
ammer
hi
i have a flat slab model
i want to define and drawing the flat slab reinforcement bars.
from edit calculation concrete line, what type of reinforcement should i select for representing the flat slab?
when i select under +upper straight, we got extra bars not need in the slab.
Re: What are the best way to drawing the Flat slab reinforce
how to delete un-needed bars in the drawings?
The reinforcement design as you specified is not made automatically in the program. You have to manually review the slab reinforcement results in the perspective view.
You can define the reinforcement area requirements for the selected loading combination for the slab component in the Shell results tab in the visualization dialog.
You can visually monitor the tension and pressure regions from the color change in the diagram, and you can also reach numerical values by moving the mouse over the diagram.
Hi friends
Thanks for the reply
I know that method
But i have an issue while drawing the bars and should exactly like the vesualization option
Would you please draw the bars as you defined it in your example
Mark "Set existing rebar area" and enter a bar diameter and spacing. If the entered dimater and range are equal to or more than the required reinforcement area for the relevant load combination it is visually colored blue.
You can applye this reinforcement in the required area by considering the developmeny length conditions.
Hi friends
Many thanks for your efforts
For my above model slab spanish villa
Could you re design and assign the reinforcement bars for the all slab and complete the drawings?
This will helps me alot.
With regards
hi Levent
have a good day
would you please to make a slab reinforcement drawings for the my model villa
it will helps a lot.
ammer":134vaopk said:
hi Levent
have a good day
Hello Mr. ammer
Reinforcement design and drawing of beamless slab systems is creating according to the choice of "upper + under straight reinforcement" type option to provide design moments and / or minimum percentage conditions in the program.
you can draw the formwork plan yourself manually by using the reinforcement areas given in the 3D display instead of using the formwork plan that created automatically by the program.
Please remember that there is negative design moment requied for upper side of slab section. We recommend that you should use "upper + under straight reinforcement" type option to prove these design moment.
