izmirli_35_35
When we load beams with wall load, can we have that beam scanned in another color? Thank you...
"izmirli_35_35":1ymoexnn" said:When we load beams with wall load, can we have that beam scanned in another color? For example, in the beam settings, select a scan type and color for the 20-inch wall and give it a name as a favorite. Similarly, make adjustments for other situations. You will get a list in this way. Choose the name you gave according to the wall and color type you defined while defining the beam. Depending on the setting, the beams will appear in the color and scan you requested.
"izmirli_35_35":1vvsw2i8" said:Or how we can see which beam is loaded with which load on the screen from the shortcut. What I want is to be able to see two or three types of loads in different colors...[/quote ] You can examine the element loads in the 3D frame.
