We will dig a hole in one of the compartments at the bus terminal where the maintenance of buses etc. is done so that the officer can work there. The dimensions are not very large, the depth and width will be 1m, and the length will be 3m. Would it be sufficient to return with a 30cm curtain or should I consider the surcharge load arising from the weight of the bus (18ton) and make it as a retaining wall? I would be very happy if you could provide sample project assistance with your valuable advice.
Log in or register now.
