v6.0051 update
admin
Administrator
Staff member
ideCAD Static v6.0051 is now available. You can update your program by downloading the installation package from the address
. ideCAD Static 6.0051 new possibilities 1.Response spectrum analysis with real dynamic analysis 2.Automatic conversion of imported (dwg/dxf) 2D architectural projects into 3D ideCAD Static objects 3.Circular and circular, arc, Calculation, reinforced concrete and drawing of spline vs beams 4. Ability to choose similar floors in beam extensions 5. Instant and time-dependent deflection calculations of rib and cassette slabs according to TS500 6. General geometry controls with new interfaces and possibilities 7. Beams according to TS500 and TDY 2007 checking the dimensions of the columns 8. Checking the dimensions of the columns according to TS500 and TDY 2007 9. Checking the dimensions of the wall according to TS500 and TDY 2007 10. Checking the dimensions of the foundation elements according to TS500 and TDY 2007 11. Option to increase the Winkler springs according to the raft limit. (Pseudo coupled method for ground springs) 12.Multi-processor support 13.Speed optimizations in analysis and CAD interface 14.Acceleration in reports 15.Rigid diaphragm options on the basis of slabs 16.Program view selection 17.Recalculate button for reinforced concrete dialogs (Full reinforced concrete+regulation checks) ) 18.Plot function command (Graphic function display) 19.Automatic naming of columns with axes 20.2 Accelerating the transitions between windows 21.3 Examining the ground stresses in the result inspection window 22.Displaying the areas exceeding the soil safety stress on the basis of loading 23.Examination of the loads in the system 24.New element Examination of the effects of the bar elements after the analysis with the interface of examining the end force diagrams and analysis results 25. Printing the foundation plan in the General Layout Shapes Report 26. Maximum reinforcement spacing parameter for the selection of flat reinforcement in beams 27. New reinforcement selection algorithm based on the maximum number of reinforcement in beams 28. Being able to navigate through the faulty elements in the report program in order 29. Considering the floors in object naming 30. Determining the user's total deflection upper limit conditions by the engineer 31. Fixing reinforcement in slab, rib, cassette, reinforced concrete dialogs on continuous and single foundation 32. Project and writing license information on the index page as well. Examining the active floor or selected elements in 33.3D frame 34. Element-based material selection interface 35. Using all floor and only floor options selected in the 3D frame in the perspective window 36. Deflection verification in conditions that do not require beam deflection verification 37 .Displaying the description of the column where the mouse cursor is on, which will facilitate the examination of long reports 38. Considering the wall object defined on the tile in the slab analysis Ability to save a project file in old version format with the start of version 39.6.0012 40. Example time history acceleration records were created. v6.0050 Architecture and Demo versions installation package is currently being prepared...
Hello, "time history sample acceleration records" has been added to version 6.0050. The program will be uploaded to the site as version 6.0051. That's why it won't open...
I UPLOADED THE UPDATE AND MY FIRST JOB WAS LOOKING AT ONE TWO UNCHARGED ERRORS IN THE DRAWING. YOU FIXED IT. HOW WONDERFUL YOU ARE. WE CAN SEE HOW GOOD JOB YOU DID BY CHOOSING YOU.
In v 6.0012, the options for axes in automatically renaming objects are not included here. It gave us more options. can it be reinstated? We were doing the order of the axles as we wanted.
Hello, Mr. Hakan, I just downloaded the 6,051 version, but the program only opened in 1 of my 10 attempts. It gets stuck in the hint window on boot. Version 5 opens without problems. I've tried different things with no results. Greetings. Suat Yildirim
"suatyy":2ntd1883" said:
Hello Mr.Hakan, I just downloaded the 6,051 version, but the program only opened in 1 of my 10 attempts. It gets stuck in the hint window at startup. The 5th version opens without any problems. I tried different versions and no results. Greetings. Suat Yıldırım[/ quote] Mr. Suat Hi, hold down Crtl+ Shift and double-click the program, so try to open it by clearing the registry.
