I looked at the project in general. First of all, do not limit the beam reinforcements to 12. Give a higher diameter reinforcement selection so that the number will decrease. There should be no problem in settling into the section. Second, I would press the ribs on the high beams, not the flat beams. In this case, the amount of reinforcement of the beam in question decreases, of course, there may be an increase in other beams, but you can optimize this. In addition, the K32-33 beams are connected to the K11 horizontal beam.
