Two minor fixes...
ryildiz
1-) THE SPRING LENGTH OF THE COLUMN GIVEN IN THE BASIC APPLICATION PLAN AND THE LENGTH OF THE SPRING DRAWN AT THE VERTICAL EXPANSION OF THE COLUMN ARE GIVEN DIFFERENTLY. (1 cm is not a very big value, but I wrote it for your information) 2-) IF THE ADDITIONAL IRON DIAMETER IS LARGE, ESPECIALLY IN THE ARRANGEMENT OF THE BEAM REINFORCEMENT, THE MUTUAL ADDITIONS MATCHES THE REINFORCEMENT DUE TO THE LOADING LENGTH, AND IT SHALLS THE REINFORCEMENTS TOO MUCH. IT IS TRANSFERRED TO THE DRAWING IN THE SAME WAY. GOOD WORK.
hello... in the projects we have solved according to the new regulation, the column sprout lengths given in the basic details and the sprout lengths given in the column vertical details are given different. The sprout lengths in the basic details are given according to the old regulation...
"tavekkul":2sunvmhk" said:
hello... in the projects we have solved according to the new regulation, the column sprout lengths given in the basic details and the sprout lengths given in the column vertical details are given differently. ] Hi, This issue is in our notes. Thank you for your report.
