sonsamuray
Probably the Persistent Basic error but I deleted it still didn't work.
Log in or register now.
"sonsamuray":1p3znf73" said:Probably the Persistent Basic error but I deleted it still didn't work.You do not have permission to view link Log in or register now.
Small beam fragments occur in the beam between P09- P04 in your project. Model the beam as one piece It would be appropriate to model the beams between the vertical load-bearing elements as a single piece (beams with their names on the basement floor such as P08-P04 etc.) In addition, the beams connected in the rigid direction of the curtain wall should be connected at the end points of the curtain (K16-K17, etc.) [ url]https://www.idecadsupport.com/forum/viewtopic.php?f=5&t=6151&p=26568&hilit=curtain%2A+rigid%2A+do%C4%9Frultu%2A+ba%C4%9Flanin%2A+ kiri%C5%9F%2A#p26568[/url]"mervemnv":40nxruld" said:Hi, I have the same problem. When I want to get the basement floor beam expansions, the program closes without opening. I would appreciate your help.
