Re: SCISSOR COLUMN JOINT Hello; Use a support joint for connection to corner columns. For middle columns, use wind combination. For this, select the support combination from the menu on the top toolbar combination tab. Click once on the orange-colored fast mode text on the far right and turn the mode off. Then select the column first, then the scissors subheading. Combination menu will open, plate width, thickness, bolt etc. set the parameters and save the combination with the add to favorites button, say ok and exit. For the other ends, select the column first and then the scissors subheading. Then, from the combination properties tab that opens, enter the favorites and call the combination you saved. It has been implemented so you can see it in your project. Check it out for use in your other projects.
