First import your drawing into ideCAD by dwg import . Then enter the command read 2D architectural project from the tools menu. Select axis icon from here then select axis layer from your dwg file Select the axis lines here and say finish. In this way, your axles will be ready. The thing to note here is that your drawing is not a block. In this way, you can convert not only axes, but also other objects such as columns, walls, beams, etc. from the imported file into IdeCAD objects. Note: Before importing the drawing, you should synchronize the scaling system with the AutoCAD scale command, or with the IdeCAD scale command after importing the drawing. (m/m, cm/cm) is important for correct data entry. Afterwards, moving your 2D drawing to (0;0) can be considered as a separate recommendation.
