Hello, The findings and suggestions for data entry in the project are as follows; *In the program, no superstructure interactive solution is foreseen in the rafter raft foundation system. As in the basement floor, it would be appropriate to design the foundation system as a beamless raft on the ground floor. *In the properties of P01 and P03 panels in the basement floor, it is recommended to select the "model as shell" and "flood floor" options, and enter the upper rigid basement floor number -2 in the analysis Settings. R coefficient can also be taken as 8. *For the solution of Joint break safety(B) problems in columns, the attached "join.pdf" file can be examined. Good work
