ibrahimhalilaydoğan
Column reinforcements are not too many, where did I go wrong?
		Log in or register now.
It will remove the largest reinforcement area in the columns The design is made according to the combination effects. On the upper floors, more reinforcement may be required due to the decrease in the normal force and the moment effect. If the number of reinforcement is insufficient for the cross-section, then it should give the maximum pursantage (M) warning in the relevant column. If the column does not give an M warning, only the color is red. may be related to the problem of insufficient clamping length (ab). (See beam pa parameters TDY item 3.4.3.1 control ) You should attach the project file so that a general evaluation can be made and whether there is a situation arising from data entry."illaga":3fpga2ps" said:I had a question. I didn't want to open a separate topic when it comes to column reinforcement. My project is 3 floors. The number of reinforcements in some columns of the last floor is higher than the ground floor. I couldn't figure out why? In my columns with insufficient reinforcement, sometimes the problem can be solved when I make the column reinforcements the same starting from the basement to the last floor. In the reinforced concrete/column menu, the insufficient reinforcement appears in red, but when I make a filter/negative, the error does not appear.
