There is no problem in the report, there is a problem with the equipment
Burak B.
Hello; My problem is that; When I get a general report after taking the analysis, there is no problem. When I receive the Continuous Baseline Report, there is no problem. Afterwards, when I open the Analysis and Design---->Continuous Foundation Reinforcements window, I see that some beams are red. I couldn't understand what the problem was. I think that the frequency of stirrups and reinforcements in the foundations are too high. I would be glad if you help. Because the file is larger than 4MB, I uploaded it here
Hello, When the report is received after the analysis, you get the error of insufficient reinforcement on the TK02.TK03 and TK05 bases. Your continuous foundation width is 50 cm, increase the beam width in continuous foundations where you are insufficient. Good work
"Burak B.":327e9hns" said:
Hi, My problem is that when I get the general report after taking the analysis, there is no problem. When I get the Continuous Baseline Report, there is no problem. Afterwards, Analysis and Design---->Continuous Baseline When I open the reinforcements window, I see that some beams are red. I couldn't understand what the problem was. I think that the frequency of stirrups and reinforcements in the foundations is too high. I would appreciate your help. Since the file is larger than 4MB, I uploaded it here
Hi, In the settings of TK02-TK03-TK07-TK08-TK12 continuous basics, in the Static tab, Assembly and Flat reinforcement Uncheck the "Combine" column and analyze. In this case, the As(-) problem will be solved in the foundations. In addition; -In the General Reinforced Concrete Parameters dialog, in order to continuously solve the continuous foundations that make small angles with each other, the angle difference between is small It is appropriate to change the view direction of the TK69 foundation with the Change/Determine Beam-Foundation-Object Direction command to enter the angle value in the "Continuously accept beams" line and to solve the TK22-69-21 foundations continuously. -Make data entry in such a way that the main node points coincide on the column. (For example, TK69) Good work.
