There are situations in the project that I can't fix
Re: steel project Hello; 1- Just enter the railing before drawing. Currently, it creates problems in the analysis above the nodes of the scissors in your model. First, the main carrier system must be properly designed. 2- In order to prevent the lovers from conflicting with each other, you need to edit them from the offset section in the purlin menu. If you enter the control, you can switch it to the lover menu, this time the arrangement has been made. 3- You need to enter the stability beam from the sub-headings of the scissors. Arrangement was made for two scissors. You enter other ranges. If you hold down ctrl while entering the model, you can catch the nodal points of the scissors. 4- Enter either horizontally diagonally to the scissors on the side axle or enter the stability beam again.
