The use of hollow blocks in console flooring
koleksiyoncu
I have placed a hollow floor tile where there is a stairwell, but I am faced with this error, I would appreciate it if you could help.
"collector":2g2g2meh" said:
I have assigned a hollow slab where there is a stairwell, but I am facing this error. I would appreciate your help
-This message is given as a warning. In semi-rigid solution, you may ignore this message. We can make console drawings yourself based on the reinforcement areas from the Reinforced Concrete dialog -Alternatively, instead of the cassette tooth in the y direction, you can model with the beam command.
