Uninstall the program from add/remove programs and download ideCAD Static 7 64 bit version again from the attached link. ."civilman":3vbb2t9w" said:I AM USING WINDPWS 10 64 BIT
It looks like you are using an account with administrator rights. Is there a problem with an account with administrator rights, try it. If you call our Bursa office during the day , we can look at the problem together by connecting to your computer with remote access. 0224 2206717"gimni1907":2maoi048" said:Previously, while using Idecad Static, I had no problems, but after formatting and reinstalling, idecad did not work properly. Both the key and the demo version gave the same errors. I tried idecad 8 demo, it was the same error. Idecad only It allows me to save it in the "Documents" folder and only opens files from that folder. For example, I cannot open a ***.ide7 file on the desktop. When I try to open it, I get the file not found error. When I start a new project with İdecad, the "Documents" folder is the same when I want to save it to a location other than the route, some or all of the route is incorrect and it does not save it. It saves to the Documents folder, but
This problem started after I changed my Windows to English. I reached out by phone today and they were helpful. When I installed windows in Turkish again, there was no problem. Thank you"HakanŞahin":188ganld" said:It looks like you're using an account with administrator rights. Is there a problem with an account with administrator rights, try it. If you call our Bursa office during the day, we can connect to your computer with remote access and look at the problem together. 0224 2206717"gimni1907":188ganld" said:While I had no problems while using İdecad Statik before, idecad did not work properly after formatting and reinstalling. Both the key and the demo version gave the same errors. I tried idecad 8 demo, same error happened again. Idecad only allows me to save in the "Documents" folder and only opens files from that folder. For example, I cannot open a ***.ide7 file on the desktop. I get a file not found error when I try to open it. Likewise, when I start a new project with İdecad, when I want to save it somewhere other than the "Documents" folder, some or all of the route is incorrect and it does not save. It saves to the Documents folder, but
