The number of iterations in the analysis is too high, the analysis does not end
hydrkrmn
THE NUMBER OF ITERATIONS IN THE ANALYSIS IS CALCULATED TOO MANY AND THE ANALYSIS DOES NOT END, SO I SEARCHED A LOT WHERE I MADE A WRONG BUT I CANNOT FIND IT
Re: NUMBER OF ITERATIONS IN ANALYSIS Hello; 1- Steel beams on your two outermost axles are in one piece, they are not cut in the area where the columns are. You need to divide these 2 beams into 3 parts with the Divide command. 2- You have entered a sliding connection between the elements you entered as a wind column and the steel beams. Define a direct wind junction. 3- Enter the middle part with the secondary beam command. For the first and the last two openings, enter with the single lateral beam command. These mentioned changes have been made in your project. Pay attention to these issues in your other projects. Good work.
Re: NUMBER OF ITERATIONS IN ANALYSIS Thank you very much. I will consider your suggestions in my next projects. Good work
