The joints in the texture of the beam joints do not hold
demir
THE JOINTS IN THE TEXTURE OF THE WALL AND BEAM JOINT ARE NOT HOLD (AS ATTACHED) IF YOU CAN HELP ME, THANKS.
Re: COATING TEXTURE Hello, Since there are different elements, the material is not defined as a single piece, so the joint parts may not hold. While selecting textures from the material editor, you can reduce the error in the joint part by enlarging or reducing the texture scale part.
