in my project, the system gave an error that it could not be solved, when I said solve the foundation and the superstructure interactively...plus in the same project, although KM and RM are very close to each other on the ground floor, the report says that it is much larger than 1.20. On the top floor KM il RM is very different from each other but gives a value close to 1.20... Even in a 6*6 slab, the reinforcement is insufficient, 15 cm slab and c25 concrete..everything is normal, but I couldn't understand why A1 and these slab lines are divided, help If you do, I will be glad
(....I will send the system, but the file size is too big.. I don't receive it
