System cannot be resolved error
Re: SYSTEM CANNOT SOLVE ERROR Hello, The height of the soil layers defined for the piles in your project is not compatible with the pile heights. This information is given to you when you analyze. The top level of the ground layers is the project zero level entered in the floor general settings and is defined from top to bottom. (You can find detailed information when you search for "Soil layers" in the Directory tab from the help menu that opens when you press the F1 key.) Accordingly, it would be appropriate to add the height of the basement floor to the height of the first layer with a height of 2.65. In this case, the analysis will be completed in your project. Note: For the ground layer information, the values given in the ground report must be defined. Default ground values are used for both layers in your project.
