Hi, entered under panels -P103-P104 must always be in line with the basic panel. -Floor height 250 cm on the basement floor. However, 300 cm elevation has been given to the columns on the right side of the 7 axis. The columns on the right of the 7 axis should not be defined in the basement. Also, foundations should be defined on the ground floor. -It is recommended that the curtain between the columns S11-s16 in the basement and the curtain connected to it be connected from the same node point. (The foundations should also be connected to this node.) -The column object on the 5th floor is placed on the panel named BAP on the 4th floor. No columns are entered on the panel. Instead, the same size panel object can be entered. -It is recommended to model the basement perimeter curtains as shells. Good work
