Hi; In the Analysis and Design tab, the outer frame elements must be selected from the moment-transmitting frame section so that strong column control can be performed. However, in multi-storey structures, there is no need to control the top floor columns as required by the regulation. You will see this in the report. .Your steel elements are not connected to another steel element at the bottom anyway. Putting that aside, most of your steel columns are not connected to reinforced concrete columns either. Since they are on the floor, the program will not be able to find any vertical structural system element (column or curtain) on the lower floor to make this check. Since it is the top floor, you can read the relevant explanation in the report. For the relative displacement, a suitable carrier system should be created in both directions in order to ensure the load flow and stability in the system. It would be appropriate to place the roof cross on the middle axis and enlarge the column sections. This arrangement was made in your project. However, your reinforced concrete is also sufficient. There are some of you, please solve the warnings by taking into account.
