teknikisler
We have the support loads coming from the roof for the project of a gym building whose roof will be made of steel construction. Can we make a solution in the program using these loads?
Hello, select beam, column or panel elements. Right click You can add a Point, Uniformly Distributed or Trapezoidal Load by using the "Add Load" command in the menu.Added loads can be examined in a 3D frame by ticking the options shown in the picture in the dialog of displaying the results."teknikisler":2oro9nl8" said:For a sports hall project with a steel construction roof, we have support loads coming from the roof. Can we use these loads to make a solution in the program
