Steel purlin misidentified
sara
hello, in my project, I am trying to place steel purlins on the truss roof, but there is a faulty drawing, how can I fix it, what is the reason, I get a negative ground safety warning in t9 and t6 singular foundations, it does not improve, can you help with this issue, thanks everyone, good work
Re: steel purlin incorrectly defined Hello; The reason why your lovers are formed this way is that your points of entry are the opposite of each other, you need to match the starting points and the endings. For this reason, the easiest method is to use the clone and copy commands on the toolbar on the left of the screen after you create the first scissors, it makes modeling fast and you don't have to be careful about the directions. Good work.
Re: steel purlin is defined incorrectly I understand, thank you very much, was there anything that could be done about the foundation, could you give an idea and help on that?
If you change the dimensions of faulty foundations (For example 175*175), the soil safety stresses will be recovered in your foundations.
