eissenhover
Hello. First of all, I would like to thank the forum administrators and members. every question is answered patiently and all kinds of technical support are provided. * I did a steel pedestrian overpass study. I would like you to tell me your design recommendations and the points you see missing. in order to produce better and more economical designs. * Other than that, there is no data on individual foundations and bonds in the analysis screen. I can't see the ground controls or other data in the reinforced concrete design tab or other tabs. While I could see everything about steel elements on the steel tab, I could not see individual foundations and bond beams on the reinforced concrete tab, on the shell element tab, and briefly on the hicbi tab. * Finally, when I want to look at the downloads, I can see all the uploads in the report, but only the weight loads are displayed on the analysis screen. There is no load other than the core weight of the split beams or other elements. loads from snow cover etc.
