Hello there; Wind load, snow load, etc., by using exterior cladding for glass. You can activate the loads via the overlay menu. For the elevator's own equipment weights, you can analyze it by entering a single load at the nodal points or a distributed load on the beams. The use of single or distributed loads is related to your engineering interpretation, and you can perform accurate analysis with both. If you encounter any problem, please let us know, and we will help you solve it as much as we can through your project. Good work.
