Hello there; Stability beams were not modeled in the model you sent and there was a slenderness problem in the bottom of the truss, you stated that you know the solution. The situation in the crosses is the same, naturally the solution logic is the same. The slenderness formula is k*l/r where k is 1 and constant for braces, l is the net span of the element, and r is the radius of inertia of the section. According to our steel regulation, k*l/r should be less than 200 for pressure elements, while it should be less than 300 for tension elements. Considering the formula, you can identify alternatives for the solution. Even if your braces do not have problems in strength control, you have to meet the slenderness condition of the Steel Regulation. Good work.
