Hello there; Yes, but sap2000 does not have other special controls of moment transmitting frames and mechanism state calculation of central braces. In other foreign programs that make these calculations, these transactions are made like Bentley products. Because if you look at TBDY 2018 Chapter 9 central braced frames, there is a control to be taken as the upper limit for element design, which must be calculated with the buckling and post-buckling balance equations of the braces. For this control, it is necessary to select the frame. Because this choice is open to engineering interpretation. Generally, in multi-storey buildings, it is assumed that the outer axles work against seismic loads and the inner section works against vertical loads, but in a non-standard structure, you can make a different engineering assumption and design accordingly. For this reason, the program makes you choose these elements as a preliminary preparation.
