Stapling does not provide security. Vertical load too high
fertugrul
Good day, I am getting this error in the column in the static project, I increased the column to 100 when it was 60, but the error did not go away, how can I solve it?
Re: It does not provide stapling security. The vertical load is too much Where do you get it, if you are taking it as a foundation, you can increase the thickness of the foundation or add a column to the appropriate place.
Re: It does not provide stapling safety. The vertical load is too much Hello, If the stapling problem in the columns has occurred on the foundation, the raft foundation thickness can be increased for solution, higher strength concrete can be used, a new column can be added to the system to reduce the axial load value on the column. .. Good work
Re: does not provide stapling security. vertical load is too much Hello
"fertugrul":2tnlq1t9" said:
good day in a static project, I am getting this error in the column, I increased the column from 60 to 100, but the error did not go away, how can I solve it[/ quote] It would be better if you add your project.This information is very insufficient, but I recommend you to increase the: --Slab thickness for non-beamed slab, --Rat thickness for non-beamed raft, --or Concrete value.
"ardasepici":11fva4m4" said:
raft tile does not provide stapling security. I could not fix the problem, I would appreciate it if you could help me
Hello, -Basement floor is considered as rigid in the project, you should not accept this floor as rigid according to TBDY 2018 Article 3.3.1.1.Besides, the bearing coefficient and ground bearing strength appear as default values -For the solution of column beam joint shear safety problems, the frequently asked questions document, item 9.
Good work.
