vforvendett4
Hi The ground floor staircase is not modeled properly when making it with the route.
Log in or register now.
Thank you."Emrah YILDIZ":1s8ga0o3" said:Hi, After drawing a separate stair area for the passage of two separate landings, define a two-step staircase. After defining, set the number of steps as 1 in the staircase properties. You can review the sample staircase definition from the project below. you can also check the ladder.You do not have permission to view link Log in or register now.Good work
