Hello, To include the ladder loads in the system; 1. You should make a semi-rigid diaphragm solution. 2. After placing the ladder, you must inform the program about the support conditions of the ladder sides. For the control: 1. After the analysis, the finite elements of the staircase in the 3D frame, such as beam-floor-curtain, etc. You can see if the elements are connected one by one. If properly connected, ladder loads are fully incorporated into the system. 2. Simply; You can observe the load change in the elements that the stairs step on with or without the ladder. In the example image, the ports are indicated by the "dark arrow": Good work...
