Stair drawing help
gunay.17
I made the ladder drawing with the route command. I modeled the steps on the rotating part of the stairs one by one, and when I did this, the reinforcements were thrown one by one, piece by piece. Also, even though I support the ladder, the ladder is flowing. I would be glad if you help.
[/url] Project
Architectural project (autocad)
Construct the straight arms of the ladder and the entire swing arm as separate areas. You can watch the training video with the link about creating the stairs.
Note: Drawings of straight-armed stairs are automatically prepared in the program. you need to edit the spiral staircase drawings with the 2d drawing tools. Good work
"Levent Özpak":2y37d9du" said:
Create the straight arms of the ladder and the entire rotating arm as separate areas. You can watch the training video on the creation of the stairs.
Note: The drawings of straight-armed stairs are prepared automatically in the program. You need to edit the spiral-arm staircases' drawings with 2d drawing tools. Good work
Thank you very much, the reinforcements came out properly, my ladder did not flow this time. But the top part It's a little too forced, it's displaced by 7 mm. How can I find a solution here?
[/url]
"gunay.17":31dxfz7l" said:
Thank you very much, the reinforcements came out properly, my ladder didn't flow this time. But the top part is a bit too forced and it has a displacement of 7 mm. How can I find a solution here?
In the picture you added, the last arm is on the landing. It looks unconnected.We can help if you add a 2D drawing of your staircase.
The drawing is not smooth on the rotating parts of the ladder. What is the reason? Thanks. On every ladder I draw, it throws 8 mm reinforcements at 15 cm intervals, so it calculates the same reinforcement, is this normal?
[/url]
"gunay.17":2r2uxhra" said:
The drawing is not smooth on the rotating parts of the ladder. What is the reason? Thanks. Also, on every ladder I draw, 8 mm reinforcement is thrown at 15 cm intervals, so it calculates the same reinforcement, is this normal?
-Drawings of straight-armed stairs are prepared automatically in the program.You need to edit the drawings of revolving-arm staircases with 2b drawing tools.-Ladder reinforcements are discarded according to the negative one from the required reinforcement areas by checking the calculation reinforcements where the reinforcement axes pass, and the minimum margin and spacing conditions given in the ladder parameters.
