"okn":281r77b2" said:I DOWNLOADED THE DEMO OF IDECAD STATICS 6 VERSION, BUT I WANT TO DRAW FOR TEST PURPOSE, I DON'T DRAW THE STAIR REINFORCEMENT I CAN'T DRAW THE STAIR BOARD. I CAN'T SAY THE STAIR ANALYSIS I CAN'T DRAW. I found it easy to put the steel ladder hereYou do not have permission to view link Log in or register now.
"NYILMAZ":17cexf8t" said:Dimensions in the stair drawing are always confused like this (this error is sometimes seen in manual dimensioning in other drawings, except for the stair drawing). The problem does not appear. Can you attach the project of your drawing to the message? You can add a project for other drawings too
Hakan, take it easy, Attached is a project with incorrect dimensions and a drawing of stairs. I couldn't understand how you couldn't see it in jpeg. but this was better. This does not always happen on a manual scale. Sometimes it gets better after exiting the command with esc. Sometimes, the object is corrected by entering the edit and pressing OK without doing anything. But I encountered it for the first time in ladder automatic dimensioning. (The file size is too big, I'm sending an e-mail) Since the drawing/stair drawings icon is the same as the Drawing / Draw mold plan icon. For your information...Hi Nedim, There doesn't seem to be a problem with line and size confusion. Can you attach the project of your drawing to the message? You can also add a project for other drawings...
