Slab spacing and reinforcement in ideCAD Static 6
HakanŞahin
Administrator
In our new version, one of the most important drawing-related features is the reinforcement of slab gaps. For this purpose, gaps are drawn in real form with the Tile Spacing command. Then, if necessary, the gap reinforcement is changed by clicking the properties of the gap object. Unless otherwise defined, this reinforcement is automatically selected 2fi12 above and 2fi12 below. When the formwork plan is received in a project with a cavity definition, the reinforcements of all cavities are automatically displayed in the formwork plan. The sequence of operations is as follows: 1. Define tile. 2. Identify the gaps. 3. If necessary, change the gap reinforcement by double-clicking on the gap. 4. Perform slab analysis and get formwork plan.
I think these irons should be written as (bottom) and (top). For example, I want to use one of these irons 2fi12 and the other 3fi13. The master may not know which is on the bottom and which is on the top. In addition, the amount of iron that should be placed along the gap should be placed at the edges. so I think it is wrong to say that the setting is 2fi12.
Does the program do the calculation of this space reinforcement or does it memorize it? 2
12 down 2
12 up There were times when cross reinforcement was thrown in the type of projects I saw. that is, the gap, the right, the left, the bottom, and the diagonal 4 corners, so the program does not calculate it?
Hakan Bey wrote above in the 3rd article. These reinforcements are thrown constructively.
