izmirli_35_35
After the analysis, why am I getting this warning even though the console opening is as small as 1 m on the balconies in the lower right and lower left corners in the attached project. How should I fix the error? Thanks...
Hello , The upper slab edge of D02 slab is not connected to K47-K4 beams. Therefore, slab formation and slab analysis are inaccurate. It would be appropriate to define the slab gap of D14 slab between P03 K31 beams as two different slabs using the slab edge. Good work"izmirli_35_35":37gei6nl" said:In the attached project, on the balconies in the lower right and lower left corners, although the console opening is as small as 1 m, why do I get this warning after analysis. How should I solve the error? Thanks...
