When we select the free top column from the change settings, does it accept the nodal points at the top ends of the columns as hinges... I designed a simple system, I designed two columns and one beam, I made the tops of the columns free. I also defined support for the upper joint points. One side is sliding and the other side is fixed. Then, when I look at the moment diagram of the beam, it still solves it as built-in. So normally, it should be ql2/8 in the middle of the support, but I guess it takes ql2/12 support values for the ql2/24 span. So when we change the translation and rotations as in sap 2000, the support states are accordingly moment can't we change the diagrams..or do they only work for the translation and deflection values in idecad ... good work ....
