Shadow issue in render
bha
Good day, in the file I prepared for ide cad rendering, either the shadows are too much or the objects are shining so much that they go beyond realism, I think I could not adjust my light settings exactly. /www.sendspace.com/file/tcbksw[/url]
"bha":yuhaljc9" said:
Good afternoon, in the file I prepared for ide cad rendering, either the shadows are too much or the objects are shining enough to go beyond realism, I think I couldn't adjust my light settings properly, I would appreciate it if you could help, good work
Hello, in the physical sky tab in the Render settings, the angle the sun makes with the horizontal and vertical will determine the shadow in the project. Angle can be set to a value between 0-90. For example, when this value is 30, you can create the shadow in the noon sun; for night rendering, you can extend the shadow length by entering this value as 60-70. The angle of the sun with the horizontal determines your shadow position. The 2-dimensional lines defined in your attached project are XY Think of it as a coordinate plane.You can enter a value between 0-90 if the camera angle is in the 1st region, between 90-180 in the 2nd region, between 180-270 in the 3rd region and between 270-360 in the 4th region. Since your amera location is in the 2nd region, the angle of the sun with the horizontal can be defined as 120. If you are defining a daytime render scene, you do not need to define artificial light. You can download and review your project from the link below.
Good work ...
