S420 steel is generally not used according to TBDY2018
mertkaanari
Hello, in my project, I want to change the s420 steel to B420C according to the new earthquake regulation, but I don't know where to do it. Can you help me?
Re: S420 STEEL IS GENERALLY NOT USED ACCORDING TO TBDY2018 Hello, S420 concrete steel can also be used, provided that the tensile strength/yield strength ratio is less than 1.35 and the equivalent carbon ratio does not exceed 0.55%. This note is printed as information in TBDY 2018 Letterheads. There is nothing that affects the account. If you want, just change the name from the material properties. Other material properties are the same.
Re: S420 STEEL IS GENERALLY NOT USED ACCORDING TO TBDY2018 Hello Mr. Yasin, It would be nice if B420C could be defaulted in the next update. We have been using B420C in projects for a long time, but sometimes we do not change it out of thought. With the new regulation, most offices started to write it as B420C on their letterheads.
Re: S420 STEEL IS NOT USED GENERALLY ACCORDING TO TBDY2018
"MaFiAMAX":3k1090c4" said:
Hi Mr. Yasin, It would be nice if the next update could be B420C as default. We have been using B420C in projects for a long time, but sometimes absentmindedly With the new regulation, most offices started to write it as B420C on their letterheads.
