I would be grateful if someone with knowledge on the subject could help. Attached is the model of the retrofit project I am doing. The problem is, when I try to do a linear performance analysis, the analysis stops after the centers of mass and stiffness are calculated. No results are visible. First of all, I made static analysis + reinforced concrete and tried again, but the result is the same. The model is attached.
