it gives an error like this and when the active side lowers the ground level, how can I get rid of it. By the way, even if it saves, the reinforcements are still red, how can I fix it? I need it.!????
The red reinforcements indicate insufficient reinforcement. In the retaining wall report, it is seen that the Base tooth stirrup does not meet the required reinforcement area. If larger rebar diameters are selected in the reinforcement selection dialog, the problem will be solved.
