Report result
"Levent Özpak":3lyxca5b" said:
"erdigoksu":3lyxca5b" said:
WHEN I MAKE ANALYSIS WITH A SEMI-RIGGED DIAPHRAGM, THE FOLLOWING RESULT IS IN THE REPORT HOW CAN I FIX IT.
Could you attach the project file to the [urlquote]? =https://drive.google.com/open?id=0B4bbnNz3BMkVckpQRXl6bGtXUHM]https://drive.google.com/open?id=0B4bbn ... Xl6bGtXUHM[/url]
"erdigoksu":3uu0n23p" said:
WHEN I MAKE ANALYSIS WITH A SEMI-RIGGED DIAPHRAGM, THERE IS A RESULT. Can you attach the file?
Floor meshes are not formed correctly in the basement. Make a solution according to the assumption of a fully rigid diaphragm. (Rebuild the D06 slab) If you say that you will definitely make a semi-rigid solution, I will suggest that D05 and D07 slabs be created using the slab gap command. Good work
