render files
Payprus
idecad 6 does not merge render files. It gives an error. It shuts itself down. I would be glad if you help.
Mr. Payprus, version 6.0051 is the shutdown situation you are talking about now, and the problem will be fixed in the update that will be released in a few weeks. Now, as a solution, you can export your REN file that you want to merge and export 3DS and import 3DS into your other REN file. To paste at the correct scale here, before exporting 3ds, measure "i.e. from outside to outside in horizontal" of the entire drawing from one end to the other. When you import this dimension in 3ds, write it next to the new dimensions x in the import dialog that appears. Let same rate be marked. Check merge and select imported objects . Type the coordinate you want to place in the origin part and click all. Since the objects will be selected, you can move them to the point you want by seeing them later. Best regards
