Hello there; 1- DD-2 earthquake level should be selected for standard industrial type structures. If you did not install it to make a special check as per TBDY 2018, you need to return to DD-2 for the design to be checked. You are currently designing at low earthquake level, it is not suitable. This has been fixed in your model, but enter the location of your project and get the online or offline accelerations from AFAD again. 2- Your project is a moment-transmitting frame, not a center braced in the y direction. 3- The beams in the central braced frame must be hinged, yours transmit moment. You need to enter the properties of these beams and define them from the freedoms sub-tab to form a joint as in the image. 4- If you are not going to use a wall, you should edit the relative offset limit value as a flexible joint. When the above errors are fixed, your project will not encounter any problems. Good work.
