Relative floor drift problem
...fatih...
Hello my dear colleagues. I couldn't solve the relative floor offset problem. I tried increasing the rigidity in several ways but still not resolved. Is there a problem in the settings or do I need to increase the size of the columns too much, I would be happy if you could help. I can't make a change in the ground values, and I don't want to spoil the architecture too much.
Hello, The reason for the high relative floor drift ratios seems to be due to the ZE ground class in your project. If you have a chance to improve the ground, when you solve it as ZD, the errors are fixed. Otherwise, check out the topics below. Increasing the dimensions of the columns or turning them into curtains can be solved by adding curtains around the stairs. You can review the related topics in the forum.
