For the correct calculation model, it would be appropriate to model your curtains as shells. When curtains are modeled as shells in your project, except for a curtain, Vr>Ve condition is not met, so KAs(- ) problem occurs. If larger stirrup diameters are selected in the reinforcement selection dialog, the problem is solved. For the solution of the shear force problem in the walls exceeding the limit value, the wall dimensions can be enlarged, higher strength concrete can be used, and improvements can be made to the carrier system to reduce the shear force on the wall. Good work"unalors":3j4xtsc2" said:doesn't save when curtains are modeled as shells.
You can model the retaining wall with the retaining wall object. Currently, these curtains affect the building analysis model."unalors":5lmgrjsr" said:I made the jeans smaller so that the curtains you mentioned are shorter in length, we put them as retaining walls there
